Blows 30 amp fuse while trying to crank engine
I have a craftsman zero turn mower model number 247204111 that blows 30 amp fuse while trying to crank engine. I’ve traced entire wire harness and found no frail wires other than connector to electric clutch. Repaired connector and still doesn’t crank. I’ve also replaced battery, new ignition switch, and starter solenoid. Could electric clutch be bad and blow fuse? Need help thanks
