Will Not Power up
My laptop was running fine and had nothing happened to it.
Just Turned it off one-day and it would not turn back on.
Hi @malice9182,
It seems as though there is no power getting from the charger to the laptop to either charge the battery or to turn it on.
This could be either a faulty charger or more likely a faulty DC-In jack - Lenovo part #01FR146 (supplier example only).
Sometime the centre pin connection in the DC-In jack breaks internally due to frequent insertions and removals of the charger plug. If this is the case the DC-In jack has to be replaced as it cannot be repaired.
First check if there is 20.5V DC on the cable plug of the charger.
If that is OK next you will have to open the laptop and use an Ohmmeter to verify that both the +ve and -ve connections through the DC-In jack are OK from input to output.
Here's the hardware maintenance manual for the laptop.
Go to p.45 to see how to remove the systemboard, so that the jack can be tested and replaced if necessary. If the jack is faulty, search online using the part number only to find suppliers.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,550
4 Comments
Hi @malice9182 ,
Does it turn on when the charger is connected?
Does it indicate that it is charging when the charger is connected?
by jayeff
It doesn't indicate if it is charging or receiving power and power button does not indicate that power is being received.
by JumalHarrigan
by MSkiller BOSS
@mskillerboss
Try what is suggested in the Most Helpful Answer below.
by jayeff
