27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Questions View all
Is stand from iMac 27" 2010/2011 fit for apple thunderbolt display?
Does anyone know if I can use the stand from iMac 27" 2009/2010/2011 for Apple 27" thunderbolt display? They look same from images I can find online, though its part number is different.
Thanks,
Add a comment
1 Answer
Chosen Solution
Sadly, they are slightly different! Between the balance spring in the hinge and the alignment of the tang they are setup differently as the systems weights are different!
  • Thunderbolt display Foot Stand is Apple P/N 922-9920
  • 2011 27" Mac Foot Stand is Apple P/N 922-9834
  • 2010 27" Mac Foot Stand is Apple P/N 922-9365
Here's one source: 922-9920 Apple Base Stand for Apple Thunderbolt Display 27"
Can you tell us a bit more on what's wrong with the foot stand, maybe it can be repaired.
Score 1
6 Comments:
@danj - Thanks Dan, my understanding is that its difference is at balance spring, so, the mounting holes and screws should be working, right? And since the weight from iMac itself is heavier than thunderbolt display, it should be fine to use the iMac stand on thunderbolt, but not the other way around, right?
Thanks,
by
@lovecd - What I can tell you is Apple loves tweaking the dimensions!
The mounting screws and holes in the newer foot stands are different! So I would take the safe route getting the correct part. But why are we replacing it in the first place?
Why don't you get both! Then you can physically compare, use the one that fits and return the other.
by
@danj - Good point, thanks Dan!
by
@lovecd - If you're set don't forget to score the answer and accept it - Thanks!
by
@danj - Sure, will do.
by
Show 1 more comment
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 385
