Black screen (touchscreen works)
When i try to turn on my galaxy tab a 8.0 (2019) i see a black screen but its emitting some light in the dark, touch screen work i hear it unlocking and sounds work, the screen is extremly cracked you can see holes and u can see the insides of the tablet through the hole (the hole is located in a cornor) i do not know if the LCD is broken or its just the screen
Despite there being a hole there was still display and its still working fine until i accidentally dropped the tablet again and everytime i tried to turn it on all i saw was light flickering through the hole usually it woudlnt flicker
Score 1
3 Comments
can u post a pic so i can get the right screen and guild couse there's like 4 compatible digitizers& LCD Screen for that particular modal
by
@hay yew how do I do that
by
@hay yew also do i take the picture of the box but also i just want to know if its just my screen being broken or its my LCD too
by
Add a comment
1 Answer
Chosen Solution
@nguyenn "the screen is extremly cracked you can see holes and u can see the insides of the tablet through the hole" this alone is enough to declare your LCD as destroyed and I am not surprised you do not see anything displayed on it. Replace the screen assembly and re-evaluate. Use something like this video to help you with it.
Use this guide Adding images to an existing question to add images to your existing Question.
Score 1
7 Comments:
But like the thing was the hole was been there but then was still displaying as if nothing happened until i accidentally dropped it again
by
The hole is like located in a very cornor the opposite side of the selfie camera like if you were to take a selfie the hole would be located in the very bottom right cornor
by
Everytime i try to turn it on i can see white light emmitting from the hole and flicker every 0.5 seconds
by
@nguyenn there comes a time where it is just to broke to display anything.
by
@oldturkey03 so my LCD is completely broken right? And that i have to find a new screen with LCD included as a replacement?
by
Show 2 more comments
Add a comment
Add your answer
BrandonN12 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 147
