Repair guides, techniques and disassembly information for Android smartphones manufactured by Xiaomi.
Where is speed dial
..i cant found speed dial in my phone Redmi Note 11..
Add a comment
1 Answer
Most Helpful Answer
Hi @its_me_muffi
I think that it's called quick dial.
See image below for how to use it.
(click on image to enlarge)
Score 1
6 Comments:
..the fourth option Quick dial is not working on my Redmi Note 11 .. i m holding a number but it doesnt do anything .. its working on my old redmi not 4 ..
by
@its_me_muffi
Try starting the phone in safe mode and check if quick dial works.
If it does then a downloaded app is the problem. The trick is to find out which one.
You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall until it works OK. When it does the last downloaded app that was uninstalled was the culprit.
A downloaded app is one that you downloaded and installed and wasn't pre-installed when you first got it.
by
My xaomi note has no quick dial ,if I press on a number nothing happens how do I get quick dial
by
I can't believe it! The 11S have not a widget to make direct call!!! 15 years ago, the nokia devices had it as standard! Are they idiots in Xiaomi! We get new devices to upgrade the functionality and all we get is new is nice colors, new emoji app and a bunch of other ^$@@$% !!! Make a list of "what not to forget" next time you make a new device
by
I have the same issue. NO quick dial option! REALLY annoying!
by
Show 1 more comment
Add a comment
Add your answer
Bohri.Baccha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 5,168
