Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
35 Questions View all
Digitizer touch glass from series 5 works on SE?
Hello, I have successfully separate the glass from the display I damage the touch in process so I had to take out the touch , the question is the digitiser from Apple Watch Series 5 works on SE?
Score 1
Add a comment
Most Helpful Answer
Hi
Iv had a look at some replacement parts and from what I have seen it should work because most of the parts I looked at were compatible with both the SE and the series5
What I would do to be sure is use a replacement part that says it’s compatible with both just to be certain;-)
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Yes, it works! i just swapped and SE screen to an S5 LTE and works.
Add a comment
Add your answer
Stelios K. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 302
