screen is full black
screen is black but i can recieve the call by guess.
Score 1
3 Comments:
Screen change phone m30 samsung
by
Screen is black nothing I can see
by
My phone screen is getting black day by day. In starting it is very small gradually increasing
by
Add a comment
The LCD layer of the screen is most likely cracked which will result in no image being displayed on the screen. You will most likely need a new screen to resolve the issue. You can also always check the connection from the screen to the board as in some rare cases the flex cable can become slightly disconnected. Liquid damage can also cause this symptom. Just mentioning in case the device was near liquid recently.
Add a comment
If your screen is completely black but you can still receive calls, there are a few troubleshooting steps you can try:
  • Restart Your Device: Sometimes, a simple restart can resolve many software-related issues. Press and hold the power button until you see the option to restart, then try turning your device back on.
  • Check Screen Brightness: It's possible that your screen brightness is turned all the way down. Try adjusting the brightness by swiping down from the top of the screen (or up from the bottom, depending on your device) to access the quick settings menu.
  • Perform a Forced Restart: If your device is unresponsive to regular restart attempts, try a forced restart. The method varies depending on your device model, so you may need to look up specific instructions for your device.
  • Check for Software Updates: Make sure your device's operating system is up to date. Sometimes, software bugs can cause issues like a black screen.
  • Charge Your Device: If your device's battery is critically low, it may not power on properly. Plug it into a charger and wait for a few minutes before attempting to turn it on again.
  • Boot into Safe Mode: Booting your device into safe mode can help determine if the issue is caused by a third-party app. If your screen works in safe mode, try uninstalling recently installed apps or performing a factory reset.
  • Factory Reset: This should be your last resort, as it will erase all data on your device. Perform a factory reset only if none of the above steps work and you're willing to start fresh with your device.
If none of these solutions resolve the issue, it's possible that there's a hardware problem with your device's screen
Add a comment
Screen belat I am answer call tuch is ok
1 Comment:
Display Tuch is ok
by
Add a comment
so if your phone showing black but you feel THAT ITS ALIVE LIKE VIBRATING OR screen is a lil glowing that means you have a soft brick. ok now press power+vol up button then enter recovery mode then you recover from there.
Add a comment
Well black screen but still receives calls, it means the phone is powered on, but the display isn't working properly. Well you can do is check your phone for any physical damage on your phone screen and try to Force Restart the Phone if the screen is still remain full black it means Software crash or boot loop without full failure.
Add a comment
My phone screen is black
Add a comment
Add your answer
Abhay will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 24
All Time: 597
