Huawei Y7 2018 smartphone runs on Android v8.0 (Oreo) operating system. The phone is powered by Octa core, 1.8 GHz, Cortex A53 processor. It runs on the Qualcomm Snapdragon 450 Chipset. It has 2 GB RAM and 16 GB internal storage.
12 Questions View all
charging percentage not increasing of y7 pro 2019
i have huawei y7 2019 when i connects it to charger it shows charging but not increasing percentage change the charging jack but have still same issue ?? can any one help me ??\
Add a comment
Chosen Solution
Personally, before the charger port, my first step would be replacing the battery. Generally speaking, as the batteries age, they don’t charge well or even at all in some cases.
This is providing you have tried using different leads, plugs and socket.
Add a comment
Changed the charge port or tried another charger? If charger then I'd fit another charge port. If you fitted a new charge port then go over the solder joints again. You could always try a new battery too.
Add a comment
Add your answer
zen shi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 39
All Time: 527
