My touch pad is cracked
Want to replace my touch pad
نعم لوحة اللمس مكسوره
Google translation:
Yes, the touchpad is broken
Hi Saif,
On virtually every smart phone I know of, the touch screen or digitizer is bonded to the LCD or OLED display, so even if the picture is fine, if the front glass is broken or the touch screen isn't working, the only solution is to replace the entire screen assembly.
On your phone you have two choices, you can get the display with or without the frame. If you buy the one without the frame, then you have to separate the screen from the existing frame, which can be a little bit difficult, but not significantly harder than other phones.
For the version with the frame, you don't have to separate the display, but since the frame is what holds everything else in the phone, you end up having to transfer virtually all of the parts from the old phone to the replacement.
I think overall the amount of work is about the same between the two choices, but the ones without a frame are generally a little bit cheaper if that's a consideration.
Good luck with your repair!
Ni pas touché de afficher
Mein apna display change karna chahata hu
@monukumar11836 and everyone else interested in this question, I'm sorry to say that iFixit doesn't have a guide to show you how to replace the screen on your Galaxy M11, but the good news is there's a Spanish site called Nadie Me Llama Gallina (Nobody Calls Me Chicken) that does! Used with the Chrome browser and its built in translation, the guide is quite usable even if you don't speak Spanish.
Manuales / Samsung Galaxy M11 / Fullscreen
This only shows the method of replacing the screen with the frame already mounted, which is the preferred way to do it as the screen comes permanent fixed to the frame so you don't have to worry about resealing it. You can undoubtedly find YouTube videos online showing you how to replace the screen by itself; the procedure is significantly different.
And if you decide to do this, take lots of pictures as you work on your phone and use those to create your own guide here on iFixit for the benefit of those who come after you! It's easy and fun and will benefit the community.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 778
5 Comments
I wanna replace my touch pad
by Raj makwana
Do you mean your screen?
by Duck
Display replacement please
by Rathnappa A
@rathnappaa I hate to say RTFM, but seriously, RTFM. (Read The Effing Manual, in geekspeak). All the information you're looking for can be found in my answer below.
by Jerry Wheeler
My mobile touch glass cracked and the display automatically works onwards with didn't me touch the screen
by M11
