The Beats Solo Pro is for the listener who's always on the move. Noise cancelling is surprisingly effective for a pair of on-ear headphones. Although the sound signature remains bass-heavy, as is emblematic of Beats, it rarely overpowers vocal reproduction.
14 Questions View all
Why is my solo pro just blinking white light non stop for hours?
It’s just blinking white light for over 24 hours now and it doesn’t connect or turn off even when I tried all the resetting techniques online it’s pretty much useless and sitting there now
Score 4
Add a comment
Most Helpful Answer
Hi
This issue is usualy caused by the logic board or the battery
Here’s what to try!
Try leaving them so that the battery goes flat and then try charging them up
You could also try disconnecting the battery by following this guide(this usually works in most cases)https://m.youtube.com/watch?v=SBeHaqnw45...
If the above doesn’t work I would try replacing the battery which uses the same link above
If all these don’t work please let me know
Hopefully this helps
Any questions please ask
Score 2
1 Comment:
I just destroyed my headphones trying to unplug the battery 😭😭 thanks so much apple
by
Add a comment
Hello. Tried all your steps.
Finally changed the battery. And it start again blinking white do you know what I can do more
Score 1
Add a comment
Add your answer
Albert Eintein will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 47
Past 30 Days: 179
All Time: 10,826
