A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
44 Questions View all
I have 3 broken pins on the connector it attaches to LCD flex CABLE
SAMGUNG GALAXY TAB A 7 10.4
I have 3 broken pins on the connector on the end of LCD flex cable that attaches to motherboard .
Do just need to order new flex cable ?
Please Help lol
Is there a trick to get around this or just get new one
Pic connector with the broken pins and the whole LCD flex cable and what it snaps to on motherboard
Add a comment
1 Answer
Chosen Solution
Hi Cynthia,
In theory, it is possible to replace the broken connector on the flex cable. However, doing so requires soldering skills that are just a step above us ordinary home repair mechanics abilities, so unless you're a whiz with hot air desoldering and have microsoldering skills, I'd say just splurge the $14 USD and replace the cable. You can easily pick one up from many vendors; here's just one of the first ones I ran across on Amazon.
Amazon.com: 2X LCD Connection Connector Ribbon Flex Cable Module Replacement Compatible with Samsung Galaxy Tab A7 10.4 2020 T500 : Electronics
Since you've gotten this far, I'm going to assume you don't need any repair help, so I'll just wish you luck and say that I'm confident once you've got your replacement part you'll be back to putting your tablet to good use. Or bad - not for me to judge. :)
P.S., Wasn't really able to tell if the motherboard connector was going to give you any problems or not; the photo is too out of focus to get a good look at it, so if you wanted to take another and repost, we'll be glad to examine it and try to make sure there isn't anything wrong.
Score 1
Add a comment
Add your answer
Cynthia Risner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 212
