Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Is there a maximum storage capacity?
My Mac Mini Late 2012 has a Fusion Drive (1 TB HDD and 128GB SSD) and it will not reinstall MacOS because the HDD SMART status is failing. Since the hard drive has to be replaced, I'm looking to upgrade it to an SSD and I'm wodering if there's a size capacity. Can I replace the HDD with a 2 TB SSD? If not, could I replace it with a 1 TB SSD?
Thank you in advance!
Add a comment
Most Helpful Answer
A 2TB SSD should work fine. The 2012 models do not have a reachable storage limit due to being UEFI.
Score 1
Add a comment
You will want to remove the blade SSD within the Fusion Drive set.
I just upgraded my 2012 with a new 4TB SSD to hold my media and will likely add in a second.
Think about getting a new blade SSD 512 GB or 1 TB for your OS and apps. It will make your system sing!
Score 1
Add a comment
Add your answer
Tyler VZ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,041
