Why is help displayed in the camera data display window?
After installing a fresh battery the word "help" is displayed in the data display window of the camera. There is no function when the shutter release is pressed, no film advance nothing is working.
Add a comment
1 Answer
Most Helpful Answer
Hi @cuzz
According to p.94 of the user manual, help indicates a winding motor problem.
The solution offered is to remove the battery and then re-install it.
What is the battery charge being shown by the 4 bar indicator in the data panel when you turn the camera on?
Just verifying that you installed a 2CR5 Lithium battery? Maybe check the voltage of the battery. It should be 6V. The shutter is locked when the battery has been depleted.
Score 1
Add a comment
Add your answer
Daniel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 259
