Repair guides for Microsoft's Surface Pro 8, released on September 22, 2021.
13 Questions View all
What type of SCREW is for the SSD back cover on the Surface Pro 8?
I know Torx 3 screwdriver is required to remove the SSD, but if the retention screw is lost, what exact size screw requirements do I need to obtain a replacement?
Score 1
Add a comment
Most Helpful Answer
I don't know the exact size.
For minimal cost why not just buy a selection of small screws - it doesn't have to be Torx as Philips is fine.
Try them gently until one screws in easily.
https://www.xda-developers.com/replace-s...
Score 1
Add a comment
The diameter of the screw is m 1.2. The tricky part is to find a fastener so that the screw can hold the SSD. So far I only could find Screws which were too long. I shortned one to fit correctly but the problem with the fastner still gives me headache.
1 Comment:
If your Screw Strips, like the one of my GF did, you will need a M 1.2 x 2 Screw and a washer to secure the SSD again. I got mine here: https://online-schrauben.de/shop/
They aren't cheap but the fit, aren't too long and work properly, unlike the ones you get from Amazon.
The dimensions I used are:
DIN 84 ST M 1,2 x 2 (Screw)
ISO 7089 A2 200HV 1,6 (Washer)
Have a good one guys.
by
Add a comment
Add your answer
Rob Blakemore will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 77
All Time: 1,722
