Phillips 2.0 × 2.5 screwdriver, which ifixit kit has it
Hi, I don't understand what Phillips 2.0 × 2.5 means besides it's a Phillips screwdriver. I am trying to remove the ram from a HP zBook 15 fury. Thank you!
@wilmalee2 I believe that would you are reading as "Phillips 2.0 × 2.5" is actually Phillips M2.0 × 2.5 which means its a 2mm thread and the screw is 2.5 mm long (thread length). With a 2MM screw your screwdriver is most likely a PH 0 or PH1 The Minnow kit Minnow Driver Kit will have those as well as all the other kits. If you do more work on computers/electronics go for the big guns. Pro Tech Toolkit Those kits are all awesome.
Hi I have the Pro Tech Toolkit and those don't work for some reason. It's like it won't latch on to the screw. :(
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 302
I talked to HP support and they say Magnetic Phillips P1 screwdriver. I guess the ifixit tools are not magnetic?
by Wilma Lee
@wilmalee2 not sure why the magnetic would make a difference but no, they are not. Get a small fridge magnet and attach that to the driver to make it magnetic.
by oldturkey03
