The HP Elitebook x360 1030 G3 is a 13.3" two-in-one laptop released in 2018. This model name can be found on the underside of the laptop in "Project Name."
10 Questions View all
The charging port is wobbly what part should I purchase to replace it?
The charging port on my hp elitebook 360x 1030 is wobbly and only works if I lean it on the side and wiggle and angle the cable end just so. What should I purchase in order to fix it? Everything else seems fine, l'm not too concerned about battery life.
Score 1
Add a comment
1 Answer
Chosen Solution
@mandymoomin this one uses a USB Type-C power connector which is soldered to the motherboard. You'd be looking for a part like this and somebody who can solder this particular part. Not an easy task due to the" hidden pins" There are a couple of good board level repair techs on here but suggestions are only of use if you are in the USA
Score 1
1 Comment:
Ah, thank you so much. I was hoping to be able to do it myself, but that sounds beyond me. I'm not in the US unfortunately.
by
Add a comment
Add your answer
Mandy will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 24
All Time: 238
