Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
Random colors on screen
Hi there, my parents recently found their first iPhone and gave it to me, they said there were no issues, but when I charged it, the screen started showing random colors, I could tell it was responsive as the brightness was changing in the place where the slide to unlock text is. I’m able to hear sounds from the phone when clicking the emergency call button and tapping where the numbers would be. All help would be appreciated!
Update (09/25/2022)
Here is an image of the issue
Score 1
Add a comment
1 Answer
Chosen Solution
Hi
This issue is usually caused by a damaged screen or loose screen connector
You will most will most likely need to replace the screen but I would open it up first and try reseating the display connector by following this guide
iPhone 4 (GSM/AT&T) Screen Replacement
If reseating doesn’t work you will most likely need a display replacement which you can find liked below
https://www.replacebase.co.uk/iphone-4-r...
Hopefully this helps
Any questions please ask
Score 1
3 Comments:
Hey there @HelloMacOS I tried reseating the connector, the screen started to show properly in the center, with some random colors around the edges of the screen, I then tried signing in and the screen started showing colors again, I even cleaned the connectors, it still didn't work. Thanks for your help!
by
@TechVid
Your most welcome
You will most likely need a new screen:-)
by
Oh ok, thanks again!
by
Add a comment
Add your answer
TechVid will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 150
