The Apple Watch Ultra with its 49 mm case seems like a roided out Apple Watch. It was announced on September 7th, released on September 23, 2022, and is the first Apple Watch certified MIL-STD 810H and EN13319. It features a customizable Action button and L1 and L5 GPS.
7 Questions View all
The hole above the crown
All the holes on the Apple Watch ultra are seated with a mesh spanned across the holes and looks to be seated with a tight span.
The mesh in the hole above the crown looks wrinkled. Can someone confirm this is normal and not a defect? Or is this some sort of a bellow?
Add a comment
Most Helpful Answer
Could be the valve toa evacuate water after you've been swimming. Should be a setting on the watch for it.
Score 1
Add a comment
Looks like that hole is leading to a barometric sensor. It also has a route to the band slot.
Score 1
2 Comments:
Does it look like a wrinkled piece of foil?
by
@Ferdi Mendes
the drilling might make it look like it’s wrinkled, but there is nothing "wrinkly" on/in that hole. The barometric sensor itself looks like a very tiny speaker cap.
by
Add a comment
Add your answer
Ferdi Mendes will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 23
All Time: 744
