Repair and disassembly information for Samsung's flagship S20 Ultra Android smartphone, released in March of 2020.
34 Questions View all
All cameras not working after replacement
When I open the camera app, I get a brief picture then it freezes and says "Warning : Camera failed" I've already replaced both the front facing camera and the rear camera module, but have the same results. I didn't see any damaged pins/connections when I took everything apart, could it be a damaged motherboard?
Score 1
Add a comment
Most Helpful Answer
more than like an issue with the motherboard
Score 1
Add a comment
@mr_shade it is possible that this is a PCB issue but there are no direct connections between components. You could check the individual components and see what that shows you.
I would also suggest to reinstall the firmware to make sure that this is not Software related. This should help located the components etc. SM G988B Schematic
Score 1
1 Comment:
Thanks for the schematic! I will take a closer look at the motherboard when I get a chance.
by
Add a comment
Add your answer
Cody Atwood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 210
