How to fix service error 5700?
paper jams on rear tray, using gloss paper or any other paper, can use front casset to run gloss paper system software will not aloud to run gloss paper from front casset
The error displayed on the Canon Printer number means the sheet feeder needs to be replaced, it can be that gears in the printer and/or sensor have become broken or faulty. 5700 is an ASF cam error most likely which is called an ASF cam sensor error
Regards,
Will
how do you fix the problem?, i know the fault, do i buy parts? do i addjust some thing on the printer? got a 'simplified service manual' to take covers off to fix it. need info of what to do, or how to it.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 27
All Time: 506
