Guides and repair information for vehicles made by SEAT, which produces small economical cars for the European market.
20 Questions View all
Engine noise from 2011 Seat Leon
I have a 2011 1.6 Litre Seat Leon Diesel. The engine has been louder than usual and there is a vibrating when sitting in the car. The vibrating is worse when the clutch is depressed. Does anyone know what could cause this?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@johndoe177 this "The vibrating is worse when the clutch is depressed" could be a bad bearing or a worn pressure plate. Check your clutch a bit better and see if the noise sounds more like a grinding coming from the clutch area. Of course it could also be a vacuum leak as well as 100 other things that may cause your engine to develop a vibration. Consider having the OBD scanned to see if it throws a code.
Score 3
Add a comment
Add your answer
John doe will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 59
All Time: 686
