Repair guides and support for Gigabyte laptops produced since May 2003.
27 Questions View all
Black screen with vertical lines
Hi there!
So I recently purchased a Gigabyte G5KD laptop (i5-11400H / RTX X3060P) - it’s just over a month old.
I was watching Netflix in bed last night and all of a sudden the screen started rolling blurred grey streaks across it, then went black with nothing but these vertical lines appearing.
As you can see I plugged it into my monitor and it works fine, but the laptop display itself seems to be buggered. I tried resetting the graphics card but sadly I’m starting to think it’s a hardware issue - which is a crying shame considering how new it is.
Any clue what it could be? Is there anything I should do before I start considering taking it to get repaired?
Thanks
Score 1
Add a comment
Most Helpful Answer
Hi
Is it possible to use the laptops Integrated gpu instead of the dedicated one as if you can try that you can tell if it’s a gpu related issue rather than a display issue(if it does it on one gpu but not another you will know what one has the issue buts that quite unlikely)
At the moment it’s looking like a display issue but we need to confirm that by trying the above
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Tried adding new ram?
Add a comment
Add your answer
Leigh Ramsay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 33
All Time: 312
