The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
83 Questions View all
Lid switch board has broken reed switch
After all of the helpful info on this site I downloaded the service manual, printed it up and worked through all the steps. Got weird values when testing per the manual but didn't get error indicator on control board so I dug a little deeper into the ridiculous latch/switch. I knew there is a magnet on the lid so there had to be a reed switch, using a magnifier I found it and saw it was cracked. It's tiny. Not sure if it's NO or NC or if there are polarity considerations etc... so I'll probably just buy a new switch. But if anyone has any experience replacing the reed switch I'd love to hear it.
Thanks to all who contribute here!
Add a comment
Most Helpful Answer
Hi,
The tech sheet for the washer shows that the lid switch is a N.O. contact i.e. closes when operated. (see p.22 for the wiring diagram).
Polarity shouldn't be an issue if there is a magnet to operate it. Like most metals, the moving contact in the switch will be attracted to the bar magnet when it is close enough to influence it and makes a connection with the other contact, closing the circuit.
Finding the correct replacement is one thing, the other is replacing it.
Once you remove the reed switch, you can measure its dimensions and then the datasheets associated with each reed switch will give the specifications which should help to find a compatible replacement that will fit.
I've never replaced one in a washer so I'm sorry I can't help you with that.
Score 1
4 Comments:
Jayeff,
We used a little door-mounted alarm when our kids were young and I knew it was in a box in the garage. It just happened to have a similar size reed switch in it. Swapped it in and now it successfully does the #00 diagnostic for opening and closing the latch.
I was wondering if it had to be wired facing a certain direction to activate. Either I got lucky or it's not a big factor.
Not sure what the voltage rating on the replacement was and if it will be sufficient but I'll find out tomorrow.
Put some fresh dielectric grease on the slider while it was apart.
Thanks!
Rob
by
@rcblum
The image in this link gives an idea of how they work.
Also the wiring diagram in the tech sheet shows that the lid lock operates at 12V DC so I would image that the voltage applied to the lid switch would be the same and not 120V AC.
by
Nice! I'll go ahead and order some that I know are rated for 12V in case this one gives up. I'm doing my work clothes as I write this, no issues yet, working normally.
I've been familiar with reed switches for a long time but never had any issues with them so was unsure if there were placement considerations. This one failed in a strange way and I wish I could post a pic, maybe this will work https://imgur.com/a/Wc71sKQ
It was hard to capture but the glass was cracked at the end right where it opened into the cavity that holds the contacts. It might've led to some oxidation? The crack was only visible from the end.
Funny to see this whole washer brought down by a tiny, old school reed switch!
by
@rcblum
Maybe find some rated for a bit more than 12V, 24V perhaps. Having a slightly higher voltage/current rating won't harm as it is not a fuse trying to protect something, merely a switch and you don't want it working too close to the top end of its rating. Maybe costs a bit more but perhaps worth it in the long term
You should be able to test the switch using an Ohmmeter and a magnet.
Connect the Ohmmeter to each end of the switch and then just place a magnet near the switch and there should be continuity through the switch i.e. 0.00 Ohms on the meter. Move the magnet away and it should show OL or infinity Ohms on the meter. Bring the magnet close again and it closes etc.
Had the same problem with my Bosch dishwasher. There is a flowmeter (fancy name for a turbine wheel with a magnet that rotates as the water flows through it and as the magnet rotates it operates and releases a reed switch.
This sent "pulses" to the control board which must count them so it knows how much water has entered the machine. The reed switch in mine went "high resistance" i.e. instead of 0.00 Ohms through the switch contacts it measured ~1K Ohm and presumably the control board didn't like it. It just stopped, drained the little bit of water that had entered and then just sat there doing nothing.
No doubt the problem with the switch was due to oxidization of the contacts but as it was enclosed in a glass tube with no apparent cracks you can't fix it, you can only replace the switch.
BTW if you want to post images or documents on ifixit here's how to do it. This works the same way in either your question or if you answer a question, but it doesn't work if you post it in a "comment" to either
Adding images to an existing question
Cheers
by
Add a comment
In order to test the switch, get your multimeter out and set to ohms or continuity. Your going to test across the switch with nothing activating it FIRST, then ACTIVATED. All you need to see is the switch change states then you will both know if it's NO/NC and if the switch works.
NO = OL to Ohms (or beep)
NC = ohms (or beep) to OL
Add a comment
Add your answer
rcblum will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 31
All Time: 140
