Fifth generation of the Lexus ES luxury sedan.
17 Questions View all
Loose strip at bottom of driver side door?
The strip at the bottom of driver side door is pulled away from door near door jamb. Do I need a new strip or can I repair this with some fasteners? It doesn't seem to snap back into place.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Mike Traughber, sounds like you have some broken clips on the moulding. I know that Lexus will try to sell you a new moulding, which probably runs around $100, or you could just try a local body shop to order those clips for you. Also, try a Toyota shop, they will be cheaper. Of course, you can always try to glue them on....:-) Hope this helps, good luck.
Score 1
1 Comment:
Couldn't have said it better. Try rockauto.com if you're having trouble finding those clips. They're great for small obscure parts.
by
Add a comment
Add your answer
Mike Traughber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 3,640
