The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
83 Questions View all
Sensing turns on and drum spins very slowly 2-3 cycles before it goes
I have a similar problem with our MVWB65FW3 commercial washer. I start the washer, light on Sensing turns on and drum spins very slowly 2-3 cycles before it goes to Wash cycle but immediately stops and returns to sensing. Repeats this cycle 4-5 times before it finally turns off. Takes a while before Lid Lock releases.
2 Comments
Did you ever finf out how to fix your washer, im having the same problem. I havr the same model as yours
by
@sandragonzalo
What does performing the diagnostic tests show, if anything? See the Most Helpful Answer below.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @smileynv
Here's the Tech sheet for the washer (assuming you meant MVWB765FW3?).
Run the diagnostics as described in the sheet and check what error codes are shown. The sheet shows the most likely causes for each error code.
Hopefully a start
Score 1
Add a comment
Add your answer
smileynava@gmail.com will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 72
