Model A1320 / 8 or 16 GB capacity
157 Questions View all
The backlight is not turning on when I use it.
My friend found a green one of these and when we tried to use it the backlight is not turning on. I dont know if it is because the screen light is burnt out, or the fact that it has been sitting in a kitchen drawer for 6 years.
Score 1
Add a comment
Chosen Solution
jaj there are two distinct possibilities. One, it is a failure on the backlight of the screen, which would be repaired by a screen replacement, iPod Nano 5th Generation Display Replacement
Two, it is a failure of the circuit that powers the screen's backlight on the main circuit board. There are no schematics for this iPod (or any other iPod really). You could check for failed components and hope it's the backlight coil. Or you could replace the logic board (as above PITA) iPod Nano 5th Generation Logic Board Assembly Replacement The failed backlight is actually a pretty common issue with the 5th Gen Nano.
iPod Nano 5th Generation Logic Board Assembly Image
Guide
Difficulty:
Difficult
iPod Nano 5th Generation Display Image
Guide
Difficulty:
Difficult
Score 2
1 Comment:
Well the iPod works fine besides the screen, but there is some light green spots on the back. i also had the thought that it may be water damaged cause of the spots, and the fact that it was in a kitchen drawer near the sink area.
But thank you for helping.
by
Add a comment
I think you need to replace the LCD as that could be causing the problem
iPod nano (5th Gen) Color Display
iPod nano (5th Gen) Color Display Image
Product
$12.99
Score 1
Add a comment
Add your answer
jaj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 84
