Can the AX1650 be upgradeed to the 6E AX210?
I have not be able to find an answer to the this question period. You guys are the only trustworthy group I trust. Would you please try to address the question? I would like to be able to take advantage of 6E. Thank you. My highest regards!
Add a comment
1 Answer
Chosen Solution
Hi @shacko
The short answer is no.
The WiFi module is integrated onto the motherboard and cannot be replaced.
Here's the service manual that will help if you wish to verify by opening the laptop to check. On p.43 is details how to remove the systemboard and it mentions disconnecting the antenna cable from the systemboard. The antenna cable is usually connected to a removable WiFi module or if the WiFi is integrated on the board as close as possible to the WiFi IC.
Score 2
Add a comment
Add your answer
Lynn Shackelford will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 135
