Repair guides and disassembly information for Lenovo's thin and light ThinkPad X1 Carbon business laptops.
67 Questions View all
computer keyboard light are on and the computer light is not working
Hi my keyboard light are on but the computer lights are on off everything else is working as far as I know I was wondering if thier is anything I can do to make the screen to turn on
Add a comment
Most Helpful Answer
Hi @owen2528,
First; Have you connected an external monitor to see if that works? This is usually the first test, because if the external monitor works just fine, you know that the computer itself is fully working and that it’s the screen that is the problem.
If the external monitor also isn’t working, then you have a computer problem. A faulty component, cable, etc.
Try connecting an external monitor and let us know if that works and you can use the computer.
Score 1
Add a comment
Hi @owen2528
Try connecting an external monitor to the laptop and check if its display is OK
If it is then with the PC on, try shining a flashlight at an angle close to the display and check if you can see any images at all (Windows desktop?). They will be very faint if there are any to be seen, so trying this in a darkened room may help to see them.
If you can see images then there's a backlight problem with the display. This could be caused by a faulty backlight power circuit on the motherboard, a problem with the video cable between the motherboard and the display or a problem in the display itself. Further testing would be required to find out what the problem is.
What is the full model number of the laptop as shown on the info label on the bottom of the laptop. There are several versions of the X1 carbon laptop e.g. gen 1, Gen 2, Gen 7 etc and if it comes to finding replacement parts knowing the exact variant will help
Score 1
Add a comment
Add your answer
Owe n will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 82
