20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
97 Questions View all
Apple Cinema Display 30" - Detected but not powering on
Hi there,
I just purchased two Apple Cinema Displays - both "30". I checked each display before I bought it -- worked perfectly. However, after driving home with the displays and plugging each into my MBP M1 via a separate USB-C to Dual DVI adapter, one display works perfectly (and is detected as Cinema HD), but the other display is showing just a black screen, and the LED power indicator is also dark, and is detected, but not as a Cinema HD display, but as "Display". Any ideas on what I should do?
This is what the System Information shows:
Apple M1 Pro:
  Chipset Model: Apple M1 Pro
  Type: GPU
  Bus: Built-In
  Total Number of Cores: 14
  Vendor: Apple (0x106b)
  Metal Family: Supported, Metal GPUFamily Apple 7
  Displays:
Cinema HD:
  Resolution: 2560 x 1600
  UI Looks like: 2560 x 1600 @ 60.00Hz
  Main Display: Yes
  Mirror: On
  Mirror Status: Master Mirror
  Online: Yes
  Rotation: Supported
Display:
  Mirror: On
  Mirror Status: Hardware Mirror
  Online: Yes
  Rotation: Supported
Score 2
1 Comment
Do you have a multimeter?
by
Add a comment
1 Answer
Most Helpful Answer
Hi
I have one of these too (with the same issue)and I have found that if I use a adapter to put it in a different port(in my case it’s DVI to HDMI)it will work just fine again
I don’t think it’s a problem with the display,I think it’s just a strange case of it acting strange and not communicating with the computer/GPU correctly
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Add your answer
Twister Murchison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 638
