The Motorola Edge is a 5G smartphone released in May 2020.
7 Questions View all
How can I reglue the backcover after ive made a repair?
ive replaced my screen and now have issues reattaching the back cover of the device do i have to heat up the glue for it to reattach?
Add a comment
You can either use a precut adhesive (dye-cut) for your specific model or take pieces of adhesive (from a roll or a sheet) and apply it to the back cover after having removed the previous adhesive. Re-using the original adhesive on your back cover probably won’t work since it has likely been deformed or weakened.
Add a comment
Buy some T7000 adhesive from ebay. Put a thin bead where the old adhesive was then replace the back. Wrap 3 or 4 elastic bands around the sides of the phone and a couple top to bottom and leave for 24 hours.
Add a comment
Add your answer
dycotomaskey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 571
