There are various different renditions of Saeco Minute coffee machines, also under the brand name Philips. All types start their Type Number with HD8xxx. Here you see a Philips HD8834.
3 Questions View all
Where does the two pipes go from the water pump.
My coffee machine is tripping the earth all the time when making coffee and when I opened it, I saw two water pipes leaving the pump, one of them (clear one) is not connected to anywhere and tip is lying loose in the machine. Is this normal ?
Add a comment
1 Answer
See Saeco Minuto Pump Replacement, step 16. The pump ist connected top two pipes, one in (the clear one) and one out.
2 Comments:
Thank you. I meant the two pipes exiting the pump. One of them seems to be not connected to anywhere. I wonder if it is a pressure valve and the distal end is juts free/loose into the tray.
by
@Alp Numanoglu : can you take a photo? Adding images to an existing question
by
Add a comment
Add your answer
Alp Numanoglu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 101
