A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
90 Questions View all
How to remove completely stripped screw?
So I stripped the screw to the point where it’s just a round hole. I tried superglue and it didn’t work, so the hole is caked with the stuff as well. How can I remove this screw? I presume I would need a drill, but what kind of drill might work for the controller?
Score 1
Add a comment
Chosen Solution
Hi
If it’s in a hole carefully drilling the screw head then removing what’s left with pliers is probably you best option
It it wasn’t in a hole you might be able to cut a slot into it for a flat head screw driver to go in into but this is probably not the best option for you
You could also try using a rubber band on the end of you screw driver
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Most Helpful Answer
C K, this is only to complete the excellent answer by @hellomacos; You could try these precision screw extractors.
I’ve had good success using those, in many cases.
Precision Screw Extractor Set Image
Product
$24.99
Score 3
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 136
All Time: 2,844
