Device and repair information for the Behringer Eurolive B212D speaker system.
32 Questions View all
behringer sonic ultramizer 110v transformer
I have this rack behringer sonic ultramizer, and its power input is 110v I need to make it support 220v how to make the input transformer accept the 220v as an input power source
Update (11/14/2022)
Score 1
1 Comment
my rack is behringer sonic ultramizer
by
Add a comment
1 Answer
Chosen Solution
elevenmark your transformers primary should be Black 0V Blue120V Red 230V Secondary are the yellow and orange/brown . The way I would try it, is to connect Black and Red to the 220V line. Disconnect the secondary lines for now, just in case. Then plug it in and measure the voltages on the secondary lines. If the voltages correspond to what they should be, you know how to connect it.
Looking at the way it is connect in your device, all you have to do is to substitute the Red wire for the Blue one. Disconnect your secondaries to make sure.
Score 1
1 Comment:
Yes it works as you said thanks a lot
by
Add a comment
Add your answer
elevenmark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 89
