Can this screwdriver open Home/Touch ID iPhone 8 plus?
I dont have any screwdriver can open that Y000 screw. So I want to buy new screwdriver but I dont know which one will solve my problem.
Hi DC,
I'm pretty sure the set shown in your second picture has a tri-point screwdriver that will do the job. You can also check out the ones available right here on iFixit that are specifically made for working on iPhones.
What is difference after number after “Y”?
It has to do with the size of the screwdriver; the bigger the number the bigger the screw it is used on. It goes down to zero, but then gets smaller so you add another zero to indicate it's even smaller; i.e., Y0 is bigger than Y00, which is bigger than Y000; you get the drift. The biggest iFixit sells is Y1, on down to Y000.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 53
