HP Envy 15t laptops include the letters “HP” in a lower-case font in the center of the display’s lower bezel.
3 Questions View all
Blue screen of death
Hello I was using my laptop with no problem since I got it so I tried updating windows and it was stuck on %100 so I restarted my laptop thinking everything would normal ones it's on but I got the blue screen instead with critical process died stop code , I have tried everything but nothing works resetting,startup repair, uninstall updates nothing works but when I try system restore I have to tick a little box on the disk I'm using but I don't have a mouse pointer to tick the box, please help me.
2 Comments
@vybzonline update which part of Windows? Update to what?
by
@oldturkey03 I was updating the windows 10 because it was not up to date.
by
Add a comment
Most Helpful Answer
How to fix a Blue Screen of Death on a Windows PC
Uninstall incompatible software.
Run a memory checker.
Check for hard drive errors.
Remove non-essential peripherals.
Replace defective or incompatible expansion cards.
Run Setup Diag after a failed Windows update.
Perform a clean install.
Regards,
Will
Score 1
1 Comment:
Thank you for your reply
by
Add a comment
Hello I will suggest you the following.
  1. Use specialized BSOD repair software.
  2. Uninstall critical third-party programs.
  3. Run SFC.
  4. Check all drivers if any driver is outdated update driver.
  5. Backup your data and clean install Windows
Add a comment
Add your answer
Abdul Malik Suraj will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 166
