Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
71 Questions View all
AirPods wont connect unless plugged in.
My AirPods Pro earbuds do not connect to my devices unless they are plugged in. They also cannot go into pairing mode, I hold the button on the back of the case for any time period and the light will not turn white. I open the lid and the light is green right away but after about 4-5 seconds of holding the button, the light shuts off then turns green again in a few seconds and doesn't stop doing that. This is a big issue because I recently got a new phone and my AirPods won't connect it.
Please Help.
Score 2
Add a comment
1 Answer
Close the lid, wait 15 seconds, then open the lid. Press and hold the setup button on the charging case for up to 10 seconds. The status light should flash white, which means that your AirPods are ready to connect. Hold the charging case, with your AirPods inside and the lid open, next to your Mac
Regards,
Will
1 Comment:
I already tried that, the indicator light will not flash white.
by
Add a comment
Add your answer
Tysen Grinde will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 302
