Lit match to close to tv now white speks are on it
I lit a match and sparks got on the tv how do i get them off
Update (12/15/2022)
[image|new_window=true] trewhhhhh
logangvr1 possible that those are burn marks. We would need to see what they look like. If they are as I suspect, then you really can't do a whole lot other than try to wipe down the screen surface. To add images, use this guide Adding images to an existing question
That was quite a match. Anyhow, this looks like it damaged (burn holes) in your screen and there is nothing you can do about it. Unless you find another identical screen and harvest replacement diffuser and polarizer sheets from it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 48
