Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
Stuck Lock Button after drop
I fell and dropped my iPhone 12. It was in a secure case, but when I picked it up I realized that the lock button was stuck and it would no longer lock. The area around the lock button is SLIGHTLY bent, not too bad, but slightly. However, there are no cracks on the phone and it is working well besides the lock button. Is there any way to fix this issue? I have been using assistive touch, but I would love for my button to work again.
3 Comments
Lock button? You mean power button? Also why are you using assistive touch? Sorry but I’m confused.
by
Yes, sorry I mean my power button. I’m using assistive touch to lock my iPhone since I can’t use the button.
by
Do you know how to open a phone?
by
Add a comment
1 Answer
Most Helpful Answer
It's definitely possible to try to fix this. but you'll need to get the phone open to do so. if the housing is the problem it may require swapping the housing to one that's free of bend depending on how significant the bend is.
Word of warning, the 12 series is a bit of a bear to get open due to the strength of the adhesive holding the screen in so you'll need a fair amount of targeted heat. And a lot of patience. You'll need to remove the battery and the logic board to get at the power button mechanism. You can see if you can bend the housing back out from the inside. Or at least make sure the power button itself it seated correctly.
Be aware if you have a 5G variant of the iPhone 12, there is an antenna soldered to the bottom of the logic board which goes up and around the battery which is really the only reason the board would need to come out since the antenna covers the screws necessary to get at the button. There isn't an iFixit Guide for either of these, but using the other Guides for reference is usually my tactic for handling this.
Some pictures of the damage may also help determine the best course of action since we don't know exactly what sort of bend you're dealing with.
Score 2
Add a comment
Add your answer
Leslie M will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 45
All Time: 1,646
