Repair guides and information for the Nintendo Switch Joy-Con controllers.
173 Questions View all
trying to replace case on nintendo switch joy cons
so long story short im trying to replace the casing on a set of joy cons and the casing that i bought... doesn't have a instruction manual in the box ._.
the rear casing won't come off after unscrewing all the screws also
help???
Score 1
Add a comment
Most Helpful Answer
https://www.youtube.com/watch?v=ymBbKWzL...
Score 1
Add a comment
Hello. I believe that the ifixit guide for joy cons might help. They explain how to take them apart and disassemble it.
Just use the part where they talk about joycons
Nintendo Switch Teardown
Score 1
Add a comment
Did you remove the rails before you took out the screws? The back plastic should come off relatively easily.
Be sure to open it like a book with the part that slides into the switch as the books spine.
Check out this guide for how to get into the case.
Score 1
Add a comment
Add your answer
timtom77 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 115
