A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
212 Questions View all
at the end it says OL
I recently replaced the water inlet valve on my maytag bravos and now every time I do a load of laundry in it at the end it says OL and the clothes are still very wet when it is done and I have to put it on drain and spin for the clothes to be spun out,I don't know if it has a reset button on it or if there is something else wrong..
1 Comment
@angieknight1970 what is the exact model number for your Bravos?
by
Add a comment
1 Answer
Most Helpful Answer
@angieknight1970 The OL code really just detects that the drum is difficult to move. This code can be indicative of a seizing drum bearing, mechanical issue that cause a jamming of the tub on one side of the washer and even a bad motor. I've had issues with worn stator spline which continuously caused the OL to come on. Replacing the rotor finally resolved this. Of course rule out all other things first.
Score 1
Add a comment
Add your answer
Angela Knight will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 611
