The Airpods Pro 2nd Generation is a revision to the original Airpods Pro. Released on September 7th, they allowed better audio, 2 times more noise cancelling, and volume controls. It also boasts a larger battery, and a speaker on the case to make finding them easier.
15 Questions View all
Why is it when I’m trying to put my charger my AirPods won’t charge
A few days ago I was charging my AirPods and i plugged in my charger why airpod light wouldn’t turn orange (which shows when it’s charging) instead it kept flashing orange I brought different chargers but none of them work on my AirPods it worked on my phones and iPads tho. I think there was a problem with my case
Score 1
Add a comment
1 Answer
Chosen Solution
You said that you have tried other chargers but have you also tried other wall pieces, a computer or power bank? Have you tried resetting and re-pairing the AirPods? Can you see the battery status of them on your phone? Are the AirPods and your phone running the latest firmware, that could be playing a part? Have u cleaned all the connectors and ports of your Airpods? Do you have a wireless charger you could test them with?
2 Comments:
Yep in fact cause I’m out a lot I mainly use my power bank to charge it. When I get home I use my wall piece. But I think the problem is the area where I need to plug in my charger into my AirPods. Do you know anyone that could fix this?
by
its more than likely the charger port although it could be the battery as well. i could perform it for you, im in DC though.
by
Add a comment
Add your answer
Roya Jay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 450
