The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
173 Questions View all
I accidentally spilled a small amount of water on my headset
I spilt a pretty small amount of water on my Meta 2 headset, it was working properly but now it isn't turning on. It still displays the powering on screen, but it won't stop. The controllers won't connect either, but nothing happened to the controllers.
Score 4
Add a comment
1 Answer
Most Helpful Answer
Hi
Just like with all water damage please don’t try and turn it on unless for testing purposes as it can make the issue worse:-)
What I would recommend doing here is taking the device apart and having a good look for where the water got in,the sooner this is done the greater chance you have of your device working again!
Once inside and you have find where the water has gotten in ,carefully clean the effected area(there’s usually corrosion where the water got in)with isopropyl alcohol until the parts and boards are water and corrosion free
After making sure no other parts were effected you can plug it in and test but if it still doesn’t work ,it will need board level repair which isn’t easy unless you have experience in that sort of field
Here’s a disassembly guide
Oculus Quest 2 Disassembly
And here’s a water damage guide(this one if a iPod but it’s the same process for resolving water damage)
Repairing iPhone Liquid Damage
Hopefully this helps
Any questions please ask
iPhone Image
Guide
Difficulty:
Difficult
1 - 2 hours
Meta Quest 2 Oculus Quest 2 Image
Guide
Difficulty:
Difficult
1 - 2 hours
Score 1
Add a comment
Add your answer
Karter Brown will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 771
