Arctis 7 Steel Series original (2016) edition
Microphone not working due to liquid inside? How to fix?
Microphone has stopped working due liquid going inside the microphone? Any chance it can be fixed?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi
From what I know after microphones get water inside of them there usually isn’t any coming back from it BUT it could be a issue with some form of corrosion so the best thing you can really do is try you best to take apart the microphone part and clean the inside with some isopropyl alcohol
If that doesn’t work you will probably need to replace the microphone
Unfortunately guides and parts are pretty scarce so I can’t leave a link to any at the moment,sorry about that
Hopefully this helps
Any questions please ask
Score 1
1 Comment:
i want to get the mic out to clean each part for some dust stuck and lower the volume of the sensed sound.
but can't see any video help me to disassemble the mic
by
Add a comment
Add your answer
brookebro98 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 676
