Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
593 Questions View all
Optical drive from 2009 MacBook incompatible in Late 2011 MacBook Pro?
Hi all, i swapped the (working) disc drive from a Late 2009 MacBook into a my Late 2011 MacBook Pro that had a broken drive and all it does is take the disc then spit it back out again, is the drive just incompatible? or is there something i could do?
I haven't tested the original drive from the 2011 in another Mac, but could it be that the logic board has an issue with disc drives?
Score 2
Add a comment
Most Helpful Answer
Hi
Have you considered that the issue could be caused by a bad optical drive cable?
As you said it could also be a logicboard issue but it might be worth trying a different cable
I don’t think it would be a compatibility issue as optical disk drives are like hard drives ,they all use SATA so they are all basically interchangeable
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Apple changed vendors and the drives firmware a few times as such some won’t work across different series.
Compare what you have across these two lists.
Add a comment
Add your answer
Dani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 63
