A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
90 Questions View all
How do I fix a broken stick piece on the Switch ProCon?
I was finished changing Pro Controller shells until I found the right stick feeling crunchy when I clicked it. After clicking, the stick would often get stuck on the right side, and when I opened the controller again, I found this part popping out when the stick was pressed. If this is part of the problem, how can I go about fixing it?
1 Comment:
You probably caught it and pulled it out assembling it. Unless there’s damage you should be able to push it back into place until it clicks. As @tomchai says, you may need a new module fitted.
by
Add a comment
1 Answer
Replace the whole joystick module.
Desoldering it is kind of tricky with soldering iron alone. Way too many soldering holes to clean up at the same time, a few of them are even connected to the beefy joystick frame, sometimes the legs are twisted to hold it in place in the hole.
Using a hot air rework station to blow from the back probably helps heating it up evenly, but you have to make sure there is no other things in the back that may be damaged by hot air.
Add a comment
Add your answer
Kev Mev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 159
