Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in 3D on the top screen.
Replacement Internal Screw Sizes
Does anyone know the sizes of the screws used internally? Several of mine stripped after using the wrong bit and I would like to replace them. I know there are replacement screw kits you can buy but they seem way overpriced.
I attempted to measure with my calipers but my measurements did not match common sizes. For example, the motherboard mounting screws measured at 1.33mm in diameter which is half way between the (what seems to be) standard M1.2 and M1.4.
Score 1
Add a comment
1 Answer
Most Helpful Answer
The 3DS XL and the 2DS XL use the same screws. You can easilly buy a screw kit for a 3DS XL for 5 bucks. Hope this helps.
Score 1
2 Comments:
Do you happen to know the screw sizes for the 3DS XL?
This would be good information to have as I have not found it documented anywhere. Plus, for $5 one can buy 100s of screws.
by
https://www.ebay.com/itm/184217821814 5 bucks is 5 bucks. Just take the easy route
by
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 1,442
