Igniter on a gas cooktop clicks all of the time when burner is off
One of the five burners on a Thermador gas cooktop clicks all of the time, even when the gas knob for that burner is turned off. The other burners work OK.
Two things can cause this problem. Most common is the ignitor switch. It is located on the burner control valve. It turns with the valve as you turn the burner on. It is a plastic moving part and the contacts will wear. Or Spillovers etc…will get in it and cause the contacts to stick.
The spark modular can cause this also. In my experience, the ignitor switch being on the left front and used a lot has probably failed.
To access the ignitor switch, after unplugging the unit remove the burner knobs. Depending on your model, you might have to remove the burners to remove the top to access the burner valves and the switches that sit on each valve. Depending on your model, you might be able to buy the switch separately or you have the by the harness with all the switches.
I have the same problem with 1 of the burner (front left) clicking when turned off. It is doing it mainly when I used the same burner and stop doing it when it is cold.
I just changed simmer control but still have the same problem. What is the ignitor switch? In the drawing attached is it the potentiometer (516) or burner vavle (507)?
thanks for you help, this is so annoying!
The switch is part of the potentioter, 516.
thanks I will try to replace it
Good news! changed the switch (25$ on ebay) and no more clicking issue. The old switch was dirty with some grease on the circuit.
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 159
All Time: 1,289
4 Comments
Hi @moeb,
What is the model number of the cooktop?
by jayeff
SGSX365CS/02
Problem is with front left burner
by Maurice Blais
Repaired it by replacing the Gas Simmer Controller model SQ120Q
by Maurice Blais
by Gaël Heskia
