The fourth generation of HP's low-cost, 11.6 inch Chromebook 11, released in 2015.
How can I replace the storage?
If the internal storage is too low, what can i do to replace another large storage?
Add a comment
1 Answer
Chosen Solution
Hi @mbwilo_m
Short answer is you can't or not easily anyway.
According to the specifications the laptop has either 16GB or 32GB of eMMC storage.
eMMC storage is hard mounted onto the systemboard i.e. it is soldered to the motherboard
One option to consider is to insert the largest capacity SD Card that you can afford or want and insert that into the laptop's card reader and leave it there and use it for extra storage space.
Score 1
2 Comments:
And couldn't the operating system be installed on the other colocated storage?
by
@davoc352
Probably not. Most likely the BIOS bootloader won't recognize the SD card port as a boot option.
by
Add a comment
Add your answer
Mishael Mbwilo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,454
