Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Questions View all
Possible to take LCD from M1 iMac 24 inch and put in early 2009 iMac?
I want to convert my early 2009 iMac 24 inch into an external monitor.
When I stripped my 2009 iMac, i noticed that the LCD was held in place by a metal frame. I thought to myself if it was possible to put the 24 inch LCD from the new iMac M1 24 inch into this one. I like the design of the older 2009 iMac, but a nicer 4.5k retina display would be so good in this old design.
Do you think it's possible?
Add a comment
1 Answer
Chosen Solution
Sadly, tech has marched on…
Your 2009 system uses a very different display standard. Think it like using diesel in your gasoline engine car or even trying to pump the diesel into your EV!
Score 1
Add a comment
Add your answer
Vincent will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 71
