Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 Questions View all
Why does audio not work on right side when using jack?
When the audio is being output via bluetooth, the sound comes from both sides and is very clear. When I try to use it with the provided cord, the right side does not produce sound and the left is significantly quieter.
Add a comment
1 Answer
Most Helpful Answer
@flyingmoons either a bad jack or a loose wire on the cable connector. Try a different cable and see if that works. If it does you know it is the cable. if it does not, it's the jack.
Score 1
Add a comment
Add your answer
June J will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 32
